Extremly Slow When DWG TO PDF With AutoCad2024
2557003216
2557003216
In first few days, it's very fast, however since yesterday, it becomes Extremly Slow When DWG TO PDF With AutoCad2024.By the way, it is fast with 2023.
0 Me gusta
Responder
Soluciones aceptadas (2)
9.392 Vistas
17 Respuestas
Respuestas (17)
Valentin-WSP
@2557003216
Consider the suggestions on these links:
Please select the "Accept as Solution" button if my post solves your issue or answers your question.
Emilio Valentin
0 Me gusta
pendean
Community Legend
Community Legend
Not seeing any issues here in R2024 with our own files (no migration from older versions was implemented either, that's often a contributing cause for some folks).
cadffm
>>"In first few days, it's very fast,"
So it has nothing to do with the productversion.
Check your
EPDFSHX
TRANSPARENCYOVERRIDE
Backgroundplot..
Supportfolder(content) of Plotter, plotstyle and pmp files
Export your settings, reset to default, test it again.
Sebastian
0 Me gusta
2557003216
thanks, but it doesn't work
2557003216
Everything works fine but plotting, now i find out plotting everything is extremly slow no matter what plotter.
2557003216
checked, it doesn't work
0 Me gusta
2557003216
Solución aceptada
I made it! I uninstalled 2024,cleaned up all files related to 2024, and cleaned up registry related to 2024,reininstalled 2024. It is brand new as the first day. Plotting fast as usual.
Valentin-WSP
Solución aceptada
@2557003216 ,
Just like the suggestion on the links had mentioned.
Emilio Valentin
2557003216
sorry, i miss that.
0 Me gusta
2557003216
HELP! I MET THIS PROBLEM AGAIN!I can't just uninstall and reininstall,anyone met this problem?
0 Me gusta
z5t6f193z54o
Observer
Observer
I have the same problem and can't solve it. Printing takes a lot of time in 2024, with all virtual printers (DWG to PDF, Adobe, PDF creator, etc.), the file is generated quickly but the progress window remains open at 100% for a very long time and blocks Autocad . I tried cleaning all files/folders as described by Autodesk, an installation on another computer with complete cleaning of all Autodesk installations (folders and registry): same thing!
Did you find a solution ?
0 Me gusta
pendean
Community Legend
Community Legend
Did you get a chance to try all the tips above? From your post you might have missed some.
background plotting and publishing also need to be turned off, and your 2024 needs to be at the 2024.1 update level (your AutoCAD's ABOUT command will confirm if you have it or not).
0 Me gusta
z5t6f193z54o
Observer
Observer
Yes I installed update 2024.1 and background publishing is disabled (I see the publishing window). I also tried with "printed with transparency" disabled but no change...
I also updated my Nvidia driver to a new certified version.
0 Me gusta
pendean
Community Legend
Community Legend
Here is a longer list of items to try from Autodesk (you've tried some of them already) https://www.autodesk.com/support/technical/article/caas/sfdcarticles/sfdcarticles/plotting-takes-a-l...
0 Me gusta
z5t6f193z54o
Observer
Observer
I tried all these steps and as it didn't work, I tried uninstalling everything, following the Autodesk advice page with all the folders to be cleaned, but the verdict is still the same. I admit that I don't know what to do anymore.
I think this is another problem, since the creation of the PDF file is done well (I can open the file) and the publication window remains open (loading bar at 100%) before moving on to the next presentation.
I need 32s for an A3 plan compared to 3.7s under Autocad 2023!
Thank you for taking the time, I welcome any idea and if I find I will post my solution which worked for me.
0 Me gusta
2557003216
Uninstall 2023, problem solved
0 Me gusta
z5t6f193z54o
Observer
Observer
ok, that simple, just trust the latest version.
Strange but it solves the printing problem! THANKS.
0 Me gusta
