Extract unit of measurement from multiple CAD files
marius.wolke
marius.wolke
Hi everybody,
I have a customer that needs to upload 4500+ CAD files to a database where it is necessary to know the unit of measurement (Meters, Millimeters,, Inches, Feet, etc.) for every CAD file that is used. Is there an easy way to do this instead of opening every CAD file seperatly?
Thnx!
Simon_Weel
What kind of database might that be? Sure, you can set the type of units with units or lunits but that doesn't mean much. Like - in drawings we make, a drafting unit is 1 mm. But for drawings of a surveyor, a drafting unit is 1 meter. There's no way to figure that out without opening the drawing.
marius.wolke
Hi Simon,
Thanks for you reply! I also can't think of anything else, but was hoping that there was some Autodesk tool which we could use to check this.
tramber
Easy througth programming. Why don't you ask in the Vlisp Forum ? There are techniques to treat your need with or without opening documents. A script may be necessary anyway.
The point is to navigate in your folders or to make a program navigating...
This is the point.
Because knowing (and writing somewhere) the value of INSUNITS or MEASUREMENT of any dwg is the easy part.
marius.wolke
Thnx, I've asked it on the VLisp forum now.
The 4500+ files are all located in the same folder if that helps?
So basically the action that needs to be done is:
1. Open the CAD file.
2. Check the UNITS
3. Wright it to a txt, csv, etc. file
4. Close the CAD file.
5. Open the next CAD file.
Thnx again for you answer anyway!
tramber
Yes it does helps !!!
You gave us the right process wich make me think that you are not far.
You can declare the folder as a support file in the first tab of the option box. What you think ? It gonna help you to open with no path
Don't forget the " when the file nam contains space.
I can help whenever needed, if I am online and not busy 😉
And my mates too
