EDITED:
In the 2nd & 4th situations, this will do that:
PEDIT
Multiple option
[select stuff]
Join option
big-enough fuzz distance to catch the nearby stuff
[another Enter to conclude]
[If the PEDITACCEPT System Variable is set to 0, and the things in your image are Lines, you will be asked whether to convert them to Polylines for joining -- answer Yes.]
For the 1st [left-most] situation, what is the criterion by which a routine would be able to determine that the horizontal connector should meet the top of the right line, and the left line should extend down to that level, rather than having it meet the bottom of the left line, with the right line extending up to that level, or something in between?
Closing the gap in the 3rd situation is another question. Is that a Polyline, or 5 Lines?
Kent Cooper, AIA
