Extend the face of a 3D object
AdamMcMillen12
Observer Observer
AdamMcMillen12
Observer
Observer
Hey guys, brand new to the forums and still pretty new to ACAD. I'm experimenting in 3D and I'm trying to create a simple roof on a box. I have made a pyramid on top of the box and exploded it to get rid of the sides that will be in my way. I have another pyramid matched up to where I need to extend the first on to, but none of the extend commands will allow me to do anything but move what is now a triangle (but used to be the side of a pyramid). Essentially, I need to turn the triangle into a trapezoid. Can anyone help me out? Screenshot attached. I accidentally made the face on the right but that is what I want to do with the left selected face. I just can't remember how I did it.
john.vellek has embedded your image(s) for clarity
Alfred.NESWADBA
Extend does not work on 3D-Face objects.
To modify 3D-Faces simply take the grips (blue markers on the corners) and stretch/move them.
- alfred -
Alfred NESWADBA
(not an Autodesk consultant)
AdamMcMillen12
Observer
Observer
When I try to use the grips, the whole face moves, it does not extend. This
is a non-issue now, acad crashed and I hadn't saved since I saw this issue.
I think I've found a different way to go about it.
Alfred.NESWADBA
You can change the type of modification option you use with the selected grip(s) by pressing <SPACE> one or more times or using right-click while you have one or more grips selected.
Also take care about the current UCS and active or inactive ORTHO mode as these options might restrict the direction to stretch the vertex.
- alfred -
Alfred NESWADBA
