Extend polygon to a line
Hello.
I have a group of closed polylines that I would like to extend up to another line.
So what I do is I select all the rectangles, and then select the mid point of the side I want to extend for every rectangle, while I keep pressing "shift"
And then move all the selected points at once up to the blue line.
However I would like to know if it is possible to select all the mid points at the same time, and not going one by one.
I have tried with the extend option, but it tells me that the object is not extendable. Also I have been trying to look for it in the forums but the solutions are some kind of routines that I don't understand. I am wondering if there is an easy way to do this.
Thank you very much in advance.
cadffm
>"r I would like to know if it is possible to select all the mid points at the same time,"
NO
And in this special case, we would use the STRETCH command instead using the Grips
Sebastian
Oh perfect, was somehting really silly, I knew there should be an easy way but I didn't know that command.
Thanks a lot!
ahmad_fawaz.93
Hi , you can use "mapclean" command on autocad map 3d ,so you can select extend lines and limit the distance maximum between it all
