extend line while keep direction
No aplicable
I want to extend a line by dragging its endpoint, but how to drag the line while keeping its direction? thanks!
0 Me gusta
Responder
Soluciones aceptadas (3)
12.110 Vistas
7 Respuestas
Respuestas (7)
user181
Solución aceptada
Grab the endpoint grip of the line then enter _EXT press enter then hover over the endpoint grip for a second then drag the line.
Alfred.NESWADBA
Solución aceptada
... or use command _LENGTHEN which has a lot of options for how to define the new length (works for arcs too).
- alfred -
Alfred NESWADBA
(not an Autodesk consultant)
imadHabash
Turn ON object snap tracking (Auto snap) F11
Edit : F11 will Tracks the cursor horizontally and vertically from object snap locations. so the best way is to select from Osnap (Extension) and as mentioned above.
Imad Habash
gotphish001
Just turn on the extension snap. It gives you a guide line going out from your line. I leave mine on so it always works. It doesn't really affect anything else by leaving it on like leaving too many other snaps on permanently does.
edit: what Imad said. That's what I get for not refreshing before I commented.
Nick DiPietro
Cad Manager/Monkey
Kent1Cooper
@Alfred.NESWADBA wrote:
... or use command _LENGTHEN which has a lot of options for how to define the new length ....
Since the OP asked in terms of dragging, the DYnamic option in Lengthen would be the one to do that.
Kent Cooper, AIA
john.vellek
Solución aceptada
HI @Anonymous,
I made a short video that shows how to lengthen a line by selecting the endpoint grip and then allowing the extension OSNAP to help. I hope this illustrates the way I like to do this process.
John Vellek
0 Me gusta
john.vellek
Hi @Anonymous,
I am checking back to see if my post or others helped you with your problem. Please mark a post or posts as accepted solutions if they resolved the issue or give me a bit more detail on this issue so we can continue to work towards getting this solved.
Please hit the Accept as Solution button if a post or posts solves your issue or answers your question.
John Vellek
0 Me gusta
