Extend command doesn't work (AutoCAD 2019)
peter.samiotakis
Message 1 of 13
peter.samiotakis
Hi!
I try to using the Extend command, extend the four lower edges using Stretch and Merge options by 15 units but I can't select the four lower edges. How can I solve that?
Replies (12)
Message 2 of 13
tramber
Looks like you are dealing with a solid.
The bottom face (a is guess) has to be offset with that kind of command :
From the solid edition tools panel
Message 3 of 13
imadHabash
As noticed in your attached image the command line waiting you for selecting ( Select surface edges to extend: ) .. now you can start select more than one edge .
Imad Habash
Message 4 of 13
peter.samiotakis
Unfortunately it doesn't work!
Message 5 of 13
peter.samiotakis
I can't select the lower edges!
Message 6 of 13
imadHabash
Is that what you're asking for ...  Click on below image .
Imad Habash
Message 7 of 13
peter.samiotakis
Doesn't work
Message 8 of 13
peter.samiotakis
I send the file Övning 14 Inte klar.dwg
Message 9 of 13
imadHabash
You may need to select a surface not edges .. >> Click <<
Imad Habash
Message 10 of 13
tramber
Busy today !
My friends gonna tell you what to do between solids and surfaces, there are ways 😉
Message 11 of 13
j.palmeL29YX
The polyline(s) and the surface(s) should be on different layers. Don't put all objects on the same layer.
Now you can disable (or freeze) the the polyline's layer before running the surfextend command.
Jürgen Palme
Message 12 of 13
j.palmeL29YX
... or the Selection Cycling can be used as shown in >>this video>>
(SELECTIONCYCLING = ON,  CULLINGOBJ must be OFF)
Jürgen Palme
Message 13 of 13
peter.samiotakis
Thanks 🙏
It works!
