Announcements
Community notifications may experience intermittent interruptions between 10–12 November during scheduled maintenance. We appreciate your patience.
Exporting to .stl file
Message 1 of 20
hi everyone, i'm having issues exporting this file i've attached to an .stl file in autocad 2015 on my mac. I go to File-->Export and then select .stl format in the file menu however nothing seems to happen after I click ok. Does anyone know how to properly export the file ...i've attached it to this thread thanks
Replies (19)
Message 2 of 20
Patchy
Only 3dSOLID will be STLOUT
Message 3 of 20
why does it give me an option to export the file as .stl? I'm confused
Message 4 of 20
Patchy
The option is always there, if the objects are not 3d then it will tell you.
What do you see in the command line after export to .STL?
Message 5 of 20
this is what happens when I try to export to .stl
Message 6 of 20
Command: _export 5261 found Selected objects must be solids or watertight meshes. 5261 objects removed from the selection set. Window Lasso Press Spacebar to cycle options5261 found
Message 7 of 20
Patchy
None of the 5261 objects were Solids.
Message 8 of 20
JDMather
Can you attach your *.dwg file here?  Maybe someone can fix it for you.
Message 9 of 20
i don't get it, I modify mesh to convert image to smooth solid and still nothing : ( I don't know why this is so difficult to convert to .stl from autocad. very frustrating : ( Select solids or watertight meshes: 0 Specify opposite corner: *Cancel* 0 found Select solids or watertight meshes: *Cancel* Command: Mesh conversion set to: Smooth and optimized. Window Lasso Press Spacebar to cycle options5261 found Select objects: 5261 objects cannot be converted. Command: Command: Command: _export Window Lasso Press Spacebar to cycle options3466 found Window Lasso Press Spacebar to cycle options5261 found (3466 duplicate), 5261 total Select solids or watertight meshes: Selected objects must be solids or watertight meshes. 5261 objects removed from the selection set.
Message 10 of 20
no problem thanks : )
Message 11 of 20
Patchy
Send .obj to JD, he has all the knowledge with Inventor, he'll show you how to get .stl from that.
Zip it if you have to.
Message 12 of 20
i think the .dwg file should be attached to this JD
Message 13 of 20
i don't see the file attached in my response...trying it again
Message 14 of 20
Patchy
File attaching here has size limit.
Zip it if Mac can do it.
Message 15 of 20
it's only 233kb should be fine, did you see the file in my replies or no?
Message 16 of 20
Patchy
There isn't any attachment.
Is this the button you used?
Message 17 of 20
yup i've submitted my reply with attachment like right now and nothing seems to show...nothing going right today lol
Message 18 of 20
trying a different browser this should work ...hopefully JD sees it : )
Message 19 of 20
Patchy
CONVTOSURFACE
THICKEN = 0.001
then you can stlout.
Message 20 of 20
JDMather
Your geometry is rubbish.
Try this
http://cubify.com/products/sculpt
