Hi Masters!!!
I have imported two pdf files into autocad to find the clashes between them. I tried export it to PDF by print option, it gives tranparent hatch but it comes blur while zoom it to 100%, then I tried by Application menu > Export > PDF, it gives good result while zooming but all hatches are comes solid fill. Please help me to convert this to pdf with transparent hatch and good quality.
Also I check Plot transparency option in page setup dialog box by opening the Page setup Manager in Output tab > Plot panel, though its plots solid fill.
Thanks in advance.
Thank You! and please 'Accept As Solution' when you found a solution, to help others.
