Exporting to DXF format
How can i export my designs so that it can be opened up a software (Aspire) for cnc machining. This software will only open up dxf files format thus i need to export my autocad drawings as such. Any solutions to this?
pendean
Community Legend
Community Legend
From inside AutoCAD...
DXFOUT command
or EXPOR command, then select the DXF output option.
john.vellek
Hi @Anonymous,
It is easy to produce a DXF file in AutoCAD.
Here are some options:
Saveas (select the File Type and version of DXF that your CNC expects)
DXFOUT is another way to produce this file.
Please let me know if you have success with this process or if you need additional help.
John Vellek
john.vellek
Hi @Anonymous,
I am checking back to see if my post or others helped you with your problem.
Please add a post with how you decide to proceed and your results so other Community members may benefit.
Please select the Accept as Solution button if a post or posts fully solved your issue or answered your question.
John Vellek
Hi
Sorry for the late response. Yes this did solve the problem and im now able to export files to the necessary laser software
