Exporting properties
yoel_jaimes72LNQ
yoel_jaimes72LNQ
Hi!
So I have this file with pipes on it, they have properties in Allgemein (General) assigned. I would to change the name of this "Allgemein" when I export into another name "Deutsche Bahn". I could manage to do this with every single element of my model, except with the pipes. I don´t know why after exporting it does not change the name or do not create the Deutsche Bahn section when exported. It is like it does not recognize the properties.
I have assigned this properties through Project Properties. It did worked for the walls that is a family system from Revit.
Attached is the Text file where I changed the name of the properties and created the Deutsche Bahn one, and the Walls and the Pipes of my Projekt. The walls are used as a blind system.
Thank you in advance!
Yoel
paullimapa
Are you referring to AutoCAD or Revit? If Revit, that's a different forum over here:
https://forums.autodesk.com/t5/revit-products-forums/ct-p/revit-products-en
Paul Li
IT Specialist
@The Office
