I have a Google sketch-up skp file and I want to convert it to IGES.
So I followed the following steps-
1) I exported this skp file as dxf from Sketch up-pro and then imported in AutoCAD 2015(because AutoCAD 2015 have export iges file option)
2) then this file opened as 2D wire frame automatically, so to make it solid I choose option conceptual.
3) then I did export it in iges form.
But the trouble is that this drawing is of metal part. And when I open this iges file in machine to make the metal part, the image opens with lots of lines on it which are not supposed to be on the design.
I also tried to smooth the surface of this part in AutoCAD using mesh-smooth option but still there was no change.
So please suggest me what should I do to avoid these extra lines.
I am attaching the dxf file with this post.
