Exporting DGN file with seed file
toznal
toznal
Hi everyone.
I would like to export DGN file.
But It has to be selected Seed file location. (I attached option image file)
What does it seed file?
And How can I specify that location? Does Autodesk support samples?
Thanks in advance.
ennujozlagam
@toznal hello,
A seed file for a DGN file is similar to a drawing template (DWT) file that contains default settings and attributes, such as working units. Selecting the appropriate DGN seed file (imperial, metric, or user-defined), and conversion units is critical to the translation from DWG to DGN. In addition, the seed file contains settings that are not present in a DWG file, and therefore inherited in the exported DGN.
These settings include working units and resolution as well as whether the file is 2D or 3D.
