AutoCAD Forum
Export to PDF
1 REPLY 1
246 Views, 1 Reply
Export to PDF
When exporting my AutoCAD 2015 files to a pdf format ... the plot table I am using sets all pens to colour "black" while maintaining linetype properties and weights etc., however in the pdf file the colours are present. I want my pdf files to be grayscale based on the linetype properties and weights.
1 REPLY 1
Alfred.NESWADBA
Have you exported the PDF or have you used _PLOT with the assiciated CTB?
And to the colors: are these colors true-color or color-index colors (from 1 to 255), only the index values can be converted with CTB, true color stay as true color.
Last but not least: what visual style did you use? If that is a rendered style like "realistic" the colors are converted to true color and so not converted by CTB, use a visual style like "2D-Wireframe" instead.
HTH, - alfred -
Alfred NESWADBA
www.ish-solutions.at ... blog.ish-solutions.at ... LinkedIn ... CDay 2024
(not an Autodesk consultant)
Forma Design Contest
