export to pdf misses raster objects
Hi there,
When exporting a mixed document to PDF, a low setting of DPI shows al content.
But when setting high DPI for raster quality the raster image object will not be shown, only the vector objects appear on the export.
I need  higher levels of DPI to keep the quality (read resolution) high as possible.
Does anyone know what could be the problem?
I found a limit of 320000 x 320000 dots for raster object but when i make a calculation i do not exceed those limits.
The attachments show exports of different DPI's for vector and raster (see filename).
Another fact is that when i change the paper size to A3 i can double the DPI setting before things go wrong.
Could anybody be of any help?
Thank you in advance,
Jeroen
J.FOCHT
A possible solution could be a setting called shadeplot. If you type MVIEW into the command line, then select the option for SHADEPLOT, ensure that the setting is turned OFF. This could cause your images to not plot.
I hope that helps or at the very least we can cross that off of the list of issues. 🙂
If this helps you then hit the LIKE button or mark as an ACCEPTED SOLUTION!
Thank You!
Jonathan Focht
Alfred.NESWADBA
>>>crossposting<<<
Alfred NESWADBA
(not an Autodesk consultant)
