export to dwfx
export to dwfx
arquiteturaL4EL9
Message 1 of 16
export to dwfx
arquiteturaL4EL9
When exporting dwg to dxf the layout does not appear entirely with a white background. Can you help me?
Replies (15)
Message 2 of 16
imadHabash
Your post headline said dwfx and your message said dxf !!! which one is your need ? also it will be good if you attache an image to see what you're talking about ?
Imad Habash
Message 3 of 16
arquiteturaL4EL9
 My problem is in the conversion from dwg to dwfx. When i open the dwfx, the layout does not appear with the dimensions defined in the autocad. I send a dwfx file as an example.
Message 4 of 16
pendean
Community Legend
Community Legend
DXF file format does not have layouts, so nothing is ever exported.
Message 5 of 16
arquiteturaL4EL9
my page is in the green file, and what happens is that only that part has a white background, when the whole page should be.
Message 6 of 16
pendean
Community Legend
Community Legend
Your DWFX file's size, 12.6k, is an indication it is empty.
Did you actively change all the 'export' settings to ensure you created what you wanted, or did you hope the default settings were going to do it for you somehow? Show us that detailed pop-up.
Message 7 of 16
arquiteturaL4EL9
I send the file with information
Message 8 of 16
pendean
Community Legend
Community Legend
What did you try this time? Now you have the wrong paper size or "what to plot" elected.
Are you sure you know how to use AutoCAD and this command?
We want to see your EXPORT to DWF command pop-up in AutoCAD in a screenshot from your AutoCAD program screen: this is the free Windows tool that can help you do that https://support.microsoft.com/en-us/help/13776/windows-use-snipping-tool-to-capture-screenshots
Message 9 of 16
Patchy
Probably used PUBLISH
Message 10 of 16
arquiteturaL4EL9
Message 11 of 16
Patchy
Attach your .DWG for a test,
It might need a pagesetup.
Message 12 of 16
arquiteturaL4EL9
dwg file
Message 13 of 16
arquiteturaL4EL9
this is what I see when I open the dwfx filethis is what I see when I open the dwfx file
Message 14 of 16
Patchy
Message 15 of 16
arquiteturaL4EL9
Thank you, but that way the layers are not active in the dwfx file.
Message 16 of 16
pendean
Community Legend
Community Legend
You are not doing enough to ensure you get what you want from that command:Capture.PNG
Maybe you need to just use PUBLISH or PLOT commands to create your DWFx files if you find this method hard to rememeber.
