Export objects with colors
I plotted some obejects filled with different color in AutoCAD2016. But when I exported them as .stl, they were all in the same color. How could I change this?
Alfred.NESWADBA
STL is a format that only transports geometry, no color, no texture (>>>details<<<).
If you need color you'll need to use a different file format.
Sorry, - alfred -
Alfred NESWADBA
(not an Autodesk consultant)
Thanks Alfred!
Could I ask what format includes both color and geometry?
Alfred.NESWADBA
In case the geometry is done/created by AutoCAD I would first say DWG or DXF, you might also look to command _EXPORT and look to the filetypes you can see here. At least it depends also on the software that should read these files.
- alfred -
Alfred NESWADBA
Thanks!!
