Hi there,
i need to export the measurements from very simpel autocad parts into a txt file. I tried it with the dataexport but i dont know how it works with the attributes, or if i need them. I would be really happy if someone could help me thanks alot!
Solved by ara_neresesian. Go to Solution.
would you please attache an image or upload your CAD dwg and tell us exactly what info you need to export ?
Imad Habash
Hello thank you for your answer,
i write a small code and therefore i will need the main informations from the CAD-Drawings of the parts. The parts will be very simple turning or milling parts. But for now I only started with a rectangle (box).
I tried to get the three measurements x,y,z of the box but I already failed with that. I only get useless informations after the export
-> see the excel
My goal is to get all the main informations of a CAD Drawing in a .txt file. For example the biggest diameter, material, length, width, special surface treatment...
Thanks alot
Greets Florian!
hi
i solved your problem with different ways (data extract - lsp - attout and....)
but i cant see in the excell the dim value cell which your object dim must be inserted in the excel file.
from your cad file i can export those tree dim vale (89.55 176.1 179.58 ) to excel or a text file
is this which you want?
Hello ara_neresesian,
that is what I need, .txt file would be great. Can you please explain how you did that with a few words. Thank you very much
HI
THIS A SIMPLE WAY WITHOUT LSP AND NONPROFESSIONAL
1-EXPLODE YOUR DIM
2-EXPLODE MTEXT TO TEXT (YOU WILL HAVE MTEXT AFTER EXPLODING DIMENSION)
3- NOW YOU HAVE TEXT OBJECTS TYPE "DATAEXTRACTION "
FLOW THE SCREEN
AFTER THAT
4- NOW SELECT ALL EXPLODED TEXT (OLD DIM)
YOU WILL HAVE THIS SCREEN
5-JUST TICK ON TEXT AND THEN NEXT
6-JUST TICK ON VALUE AND THEN NEXT
6-NOW SELECT THE DESTINATION FILE NAME AND LOCATION
ITS IS DONE
GO AND SEE YOUR SAVED FILE
BUT IF YOU HAVE TO DO THIS EVERY DAY ITS BETTER TO DO IT WITH LSP
LET ME KNOW.
I CAN DO IT FOR YOU
GOOD LUCK
Hello, thanks alot for your answer.
I created a block containing the rectangle with the measurements and i am able to export the block the way you explained it.
Do i need to create an attribute in the block with the values? I dont get the text Button at step 4 and I dont know what you meant with explode dim and text to mtext
Thank you !!
HI
I made that steps regarding to your drawing (it wasn't a block)
you dont need make a block (just explode the dim 2 times) and follow the steps
but if you have to make a block or att block ,the steps might be different then send me a file which contains your block and att,....
i have to know your block information.
i will explain what to do a.s.a.p
if you like send your file to my direct email (ara.nersesian@gmail.com)
good luck
Hi ara
thank you very much for your answer. I fixed my problem with the explode dim. Thank you!
WORKED LIKE A CHARM!!! 😁 You have no idea how much trouble I was having with this! THANKS!!!
thanks a lot bro, this is just what am looking for, hopfully this wizard is included in autocad commands, this really does not need any type of LISP routine or VBA Codding.
Thanks again.
