- Marcar como nuevo
- Favorito
- Suscribir
- Silenciar
- Suscribirse a un feed RSS
- Resaltar
- Imprimir
- Denunciar
I've been tryin to export all of the linetypes out of our current .dwg (which is our old template file) to a new .lin file.
I want to do this because we are in the process of creating a new template which is almost complete - with the exception
of adding in our linetypes.
I suggested using Design Center to copy them in, but was told not to do that because that will drag in a lot of extraneous
info we do not want in the new template.
I feel like I'm going crazy - When I'm in the old dwg file (the old template) that has the linetypes I want, I check the support path that linetypes are loading from and see its pointing to my users support path acad.lin file, however when I open that acad.lin file it only has about half of those linetypes in it. What does this mean ? Or is it pulling from another acad.lin file that I just can't find ? I've looked and looked.....
I can't seem to find the acad.lin file it's pulling all of these linetypes from.
Searching online I've found a few posts offering a .lsp routine to handle this, however each of those I've found and tried
resulted with an error message when I used APPLOAD to run the .lsp. - maybe I'm doing something wrong here ??
These are the .lsp routines I downloaded and tried so far :
export ltypes.lsp
linout.vlx
to-lin.lsp
I tried to attach these .lsp routines to this post - not sure if it worked.
If anyone has any suggestions, I would greatly appreciate it !!
Thank you
DianneV
¡Resuelto! Ir a solución.
