Anuncios
Export Layout with single Veiwport to PDF A3 Full Bleed
No aplicable
I have made a drawing inside a 420 to 297 rectangle in model view, created a new layout with a single viewport selected to fit and set the page setup parameters as in page-setupt.png. The problem is, the rectangle does not fit perfectly in the layout as seen in layout.png and this shows when the layout gets exported in PDF. I know I am missing something rather simple but could not figure it out.
0 Me gusta
Responder
Soluciones aceptadas (1)
1.079 Vistas
6 Respuestas
Respuestas (6)
Alfred.NESWADBA
it looks like your rectangle (your border drawn on the layout) does not match the ratio of the layout.
Can you upload the dwg-file?
- alfred -
Alfred NESWADBA
www.ish-solutions.at ... blog.ish-solutions.at ... LinkedIn ... CDay 2025
(not an Autodesk consultant)
0 Me gusta
No aplicable
Hello Alfred, please find attached the dwg file.
0 Me gusta
Alfred.NESWADBA
sorry, nothing attached.
Please answer to the post using your Internet browser, there you can attach files.
Answering per eMail does not forward attachments.
- alfred -
Alfred NESWADBA
0 Me gusta
No aplicable
It should be ok now, I edited the first reply.
0 Me gusta
Alfred.NESWADBA
Solución aceptada
thank you for adding the file!
Now for me it's not clear any more what your question is. From your first post:
Well, neither the viewport has a size of 420x297 as shown here:
nor the viewport is set to have a scaling of 1:1 (as you want to plot a rectangle from the modelspace, which is 420x297 in 1:1 to the plotter/PDF)
Besides of that ... if the rectangle in the modelspace is drawn to have a border on the output I would create that border in the layout's paperspace!
- alfred -
Alfred NESWADBA
0 Me gusta
No aplicable
Thank you Alfred, that solves it. I thought the height and width of the viewport were set to papersize when I selected the viewport to fit. Same with the scale when hitted extents.
0 Me gusta
