export error
export error
export error
There is always an error when I export DXF file from AutoCAD Civil 3D 2018.
I have tried to create a blank new file and do the export, and the error is still there. It means it doesn't matter if the file I am exporting is crashed or not. Are there any suggestions? Thanks!
pendean
Community Legend
Community Legend
Posting in the C3D forum is probably your better option https://forums.autodesk.com/t5/civil-3d-forum/bd-p/66
If I may ask: what is the purpose of you exporting to DXF?
Alfred.NESWADBA
Which command did you try to create a DXF-file?
  • _SAVEAS
  • _DXFOUT
  • _WBLOCK
  • _AECEXPORTTOAUTOCADDXF
...and which version of DXF?
Based on which template, "new file" in most cases, when country kits are installed, is all, but not empty. 😉
A screenshot of command _ABOUT could help too, just to know which updates are installed.
- alfred -
Alfred NESWADBA
(not an Autodesk consultant)
ChicagoLooper
What are the entities? Are they cogo points? Civil objects? something else?
Chicagolooper
