How to export a DWG file (from AutoCAD 2018) to Google Earth Map (KML format)? I tried using a solution from Google search using MAPEXPORT function. When I type MAPEXPORT command in the AutoCAD dialog box it returns with nothing except displaying 'unknown command'. Please help me to solve this issue. Thanks.
Solved by Michiel.Valcke. Go to Solution.
Hi @Anonymous
The command MAPEXPORT is available only in "AutoCAD MAP3D". I guess you are using plain "AutoCAD" so that's why it's returning as "unknown commmand" 🙂
Solution:
export 3D CAD model to .DXF (AUTOCAD 2013) format
Import DXF file to Blender (free Software)
In Blender export file as .dae
In Google Earth click Import Model
select .dae file
