Export coordinate from DWG to Excel
Message 1 of 11
Hey guys. Is it somehow possible to export dwg coordinate into excel file?
Thanks in advance.
Replies (10)
Message 2 of 11
Patchy
Have you tried DATAEXTRACTION command?
Message 3 of 11
Thank you Very Much what About the lenghts?
Message 4 of 11
Is it possible to combine the information for name, length and coordinate so I can export them out together?
For instance Vx.21 has length 2236 and coordinates x=35 and y=5975
Message 5 of 11
Patchy
Try the command yet?
Message 6 of 11
Thanks i have tried it but now i have another problem :(.
How can i make a system the coordinates, length and name work together?
for instance i want a table that says:
x=6248 y=9174 L=1128 and name vx.1
x=11288 y=9174 L=1068 and name Vx.2
etc...
etc..
Is that possible and if it is can you show it in a video? Gratitude.
Message 7 of 11
Patchy
Use FIELD for length, then Dataextraction can show both.
Message 8 of 11
Can you show it in a video? I dont really understasnd.
Message 9 of 11
Patchy
Use FIELD and label Length on the lines and edit the text with your segment name.
then use Dataextraction to get the names.
Here is an example:
Message 10 of 11
i dont understsnd can you please take my dwg and show it in a video from scratch
Message 11 of 11
TerryDotson
Preparing videos takes a lot of time and remember that all the help you get here are FREE.  It looks like you've been given some good starting information.  Actually trying it and reading about the topics discussed should get you farther along.
