AutoCAD Forum
Export Autocad Model to Naviswork include point cloud
3 REPLIES 3
guido_maniglia
298 Views, 3 Replies
Hi All,
I need to export an Autocad 3d model that include a point cloud in Naviswork.
I usually export the model in 3d DWF (.dwfx) and open it in Naviswork and save as NWD.
But when I export the model the point cloud is not inserted.
I can't insert the point cloud directly into naviswork because I can't make the origins match
3 REPLIES 3
pendean
in reply to: guido_maniglia
@guido_maniglia wrote:
... I can't insert the point cloud directly into naviswork because I can't make the origins match
Would this help solve that issue https://www.autodesk.com/support/technical/article/caas/sfdcarticles/sfdcarticles/Models-moved-after....
guido_maniglia
in reply to: pendean
@pendean
I used the solution you indicated and now it exports the point cloud, but not in the correct position
RSomppi
I would adress the point cloud issues in Navis or the program used for processing the point cloud. Find a Navis forum for advice on how to deal with this.
AutoCAD Inside the Factory
