Exploding blocks
Exploding blocks
leekennewell
Exploding blocks
leekennewell
I have a number of blocks that I wish to turn into one block.  How can AutoCAD explode that one block, such that I have the individual blocks left?  What happens when I do it is AutoCAD explodes everything in that block and i'm left with individual lines (not desirable).
ChicagoLooper
Hi @leekennewell
  1. Select the blocks using a crossing window
  2. With blocks still selected, Right-click=>Clipboard=>Copy with basepoint=>enter 0,0 on command line=>Enter
  3. In your target drawing=>Right-click in modelspace=>Clipboard=>Paste as Block=>enter 0,0 on command line=>Enter
The pasted entity (your copied blocks) is now a single block. You may now explode that entity. If exploded, they'll return to their original blocks.
You may also paste in the same drawing from which they were copied. When exploded, the individual blocks will be positioned in their original X/Y location.
Chicagolooper
handjonathan
Hi @leekennewell
Thanks a lot for posting your question to the forums!   Has the solution suggested by @ChicagoLooper helped with your issue?
We look forward to hearing back from you with more information so we can help you as a community! 
Jonathan Hand
Technical Marketing Manager | Construction
Kent1Cooper
@leekennewell wrote:
....  How can AutoCAD explode that one block, such that I have the individual blocks left?  What happens when I do it is AutoCAD explodes everything in that block and i'm left with individual lines (not desirable).
It doesn't work that way for me.  When I Explode a Block containing nested Blocks, the result has those nested ones now as independent Blocks, still Blocks, not broken into their component parts.  Are you using the ordinary Explode command, or perhaps something fancier that's meant to dig deeper in Exploding?
Kent Cooper, AIA
magnolor
Observer
Observer
I have this issue too.  How do I fix this?
cadffm
we don't know this issue. If you EXPLODE the main blockreference, the contained blockreference should be left - not just lines&more.
Please:
1. Share your productname and productversion, see command: ABOUT
2. Share a sample!
Take one .dwg with one blockreference of your BIGBLOCK (delete all other stuff), copy this blockreference, select one of them and run command: .EXPLODE
periodEXPLODE
Sebastian
magnolor
Observer
Observer
This morning, I can not duplicate this issue. Maybe the solution was as simple as a reboot and program restart.
Ron
