Explode blocks By Name
Shilpa_Dhawan
Message 1 of 23
Shilpa_Dhawan
How do i have the ability to explode a Block by using the Name of the block and not by selecting it. Is there a setting i can change?
For example, for command LayDel i can either select the element on the layer or name the layer in the command line. I want that similar ability to explode my blocks. I want to name the blocks in order to add them to a script.
Replies (22)
Message 2 of 23
imadHabash
You can use QSELECT command or SELECTSIMILAR (SEttings) command for selecting by name then you can explode them.
Imad Habash
Message 3 of 23
Shilpa_Dhawan
But that also uses mouse clicks.
Message 4 of 23
imadHabash
Those two commands will search to find all blocks by name.
Imad Habash
Message 5 of 23
cadffm
For non dynamic Blocks, use SSX
For dynBlocks, you need a 3rd party tool,
Sebastian
Message 6 of 23
Shilpa_Dhawan
Lets say the Block name is 'ABC'
Can you tell me precisely what needs to be done, please?
I have used both Qselect and SelectSimilar but never together and never without using my mouse for selection. SO i have no idea what to type here.
Thanks.
Message 7 of 23
imadHabash
As much as i understand the issue .... Click on below image
Imad Habash
Message 8 of 23
Shilpa_Dhawan
HAHA, thank you for the graphics.
But my problem is that - i cannot / DONT WANT to use mouse clicks to select 'names' under Properties. You used your mouse. I cannot add mouse clicks in my script.
I want an option like this ideally -
Explode Select Block or [Name]
Message 9 of 23
Moshe-A
@Shilpa_Dhawan ,
the comparison to laydel is not totally right. laydel erase everything on that layer and do layer purge.
on case of block,  there is possibility it has multiple references, do you want to explode them all? than purge it?
Moshe
Message 10 of 23
Shilpa_Dhawan
I absolutely understand that Laydel is totally different.
I just wanted to specify what option i wanted.
And no, the blocks i want to explode do not have multiple reference. There is only 1 'ABC' block that i want to explode.
-s
Message 11 of 23
Moshe-A
But block can have a long name to key don't you think picking it with the mouse is more simple?
Message 12 of 23
Shilpa_Dhawan
Its not what i want, its what i need to do in order to write a script.
Message 13 of 23
Moshe-A
you have an autolisp program but you do not know how to catch block by name? then show us what you already have.
Message 14 of 23
Moshe-A
@Shilpa_Dhawan ,
the following call select all abc block references in model space without any pause and return selection set (type PICKSET)
does that help?
Moshe
(setq ss (ssget "_x" '((0 . "insert") (2 . "abc") (410 . "Model")))
Message 15 of 23
Shilpa_Dhawan
I do not have a lisp, i'm writing a lowly script like a normy. I'm a beginner at this.
Message 16 of 23
Moshe-A
then share us with all your idea cause having only a command to explode block by name is not logic.
Message 17 of 23
pendean
Community Legend
Community Legend
@Shilpa_Dhawan That's the problem around here sometimes, folks are skimming your post for key words and replying to that one instead of trying to help.
You want...
1) a variation of EXPLODE command
2) that presents a dialog box with a list of all the block names in your DWG file
3) for you to select one of more from that list
4) then click OK to explode each.
Yes?
Message 18 of 23
Shilpa_Dhawan
I cant. its company work product. I cant share.
But i can tell you that -
i wrote a script to change the layers inside a block, managed that with bedit, simple, so far. Now i want to explode it. So that when its exploded the contents are of that final layer. Everythings is good except the explosion bit.
Message 19 of 23
cadffm
You got an answer, but i miss your reply..
You can use ssx or the line of lisp - for non dynamic Blocks
If there can be more than one reference you need a detail more to explode your blockreferences, for for one (non dynamic) blockref only - you have two valid answeres.
Run ssx or the ssget line first, then
run explode for object selection use "P" for Previous.
Sebastian
Message 20 of 23
cadffm
(if (setq ss (ssget "_X" (list'(0 . "INSERT")'(2 . "ABC")(cons 410 (getvar 'CTAB))))) ; Sample for selection inserts only
    (foreach i (vl-remove-if 'listp (mapcar 'cadr (ssnamex ss)))(command "_.EXPLODE" i))
Try it (directly in your commandline or in your .scr file)
Sebastian
