excel OLE updated automatically
johan.degreef
Advisor Advisor
johan.degreef
Is there a way to display an excel worksheet in an Autocad drawing (I know OLE insert) and have it update as the excel file is modified? Now i have to delete the OLE excel in Autocad and re-insert it to have the latest data.
many thanks, Johan
Inventor 2025, Vault Professional 2025, Autocad Plant 3D 2025
imadHabash
You can bring an Excel spreadsheet into AutoCAD® as an AutoCAD table object. Follow these steps:
  1. In Microsoft Excel, select the spreadsheet area that you want to import, and copy it to the clipboard.
  2. In AutoCAD, on the Edit menu, click Paste Special.
  3. In the Paste Special dialog box, select the AutoCAD Entities option. This will create an AutoCAD table that can be formatted to match the linetype and text style.
also you can follow this link >> Click <<  for more informatio . you can get your updates by DATALINKUPDATE (Command) . also you can Controls the notification for updated or missing data links by DATALINKNOTIFY (System Variable) .
Imad Habash
RobDraw
I would use AutoCAD tables but it's not a "live" connection. They can be updated but not automatically.
Rob
