>> I am having errors
Well, if we would know which errors you have (any error messages, screenshots, sample dwg-file, ...) and if we would know which software and version you are ujsing and if we would know what "when I PDF a drawing" exactly means (I understand you create a pdf from your dwg-file, but I don't see which command you used, there exist multiply ways to get this done)) ... someone might have suggestions for you. 😉
Therefor please take a bit more time to describe what you have, what you do, what you expect and what you get that differs from the expected result. Adding screenshots and/or files helps us to understand what you see/what you have.
- alfred -
Alfred NESWADBA
www.ish-solutions.at ...
blog.ish-solutions.at ...
LinkedIn ...
CDay 2026------------------------------------------------------------------------------------
(not an Autodesk consultant)
