Excel embedded as a linked OLE appears with too much empty space
Message 1 of 8
Hello everybody
Our problem with AutoCAD 2018.1.1 and Excel 2010 is as follows
Excel-table unlinked:
In Excel, marking the desired area with the mouse from top left to bottom right,
Control-C, then into the AutoCAD model space, do Control-V and the desired Excel part
is there. Of course unlinked but so far, so good.
Excel-table linked:
In AutoCAD (model space), -> Insert, -> OLE Object ..., -> Create from File, -> Browse and
Check "Link", then select the file and press "OK". Now the Excel file is inserted but it has
on the right and on the bottom side of the actually desired area half as much width and
height with additional white space included.
The borders of the wanted area of our Excel table never extend the full space of the A4-size.
How is this unwanted white space defined? Where is it coming from?
Unfortunately you are not able to trim this OLE (unless you cut it in the layout with a
corresponding viewport). Linking works fine so far in both directions, but we do not like
the Excel OLE is adding somehow unwanted white space which we can not define. The
wrapper preview in Excel does show the desired area!
Is the problem coming with Excel or with AutoCAD? The page setup (Excel) is an A4 and it
is defined with the usual small margins all around, the inserted Excel OLE comes out nearly
as a square (100% to 99.188%) with this kind of linking. Does anyone have any idea to
solve this problem?
Regards, Chris
Replies (7)
Message 2 of 8
jggerth
If you need to control the appearance of the imported data, you need to NOT use OLE.    Explore datalinking and tablestyles instead.
OLE sorta works with AutoCAD, but only sorta.  There are better ways to accomplish the same end result.
Message 3 of 8
Hi JGerth
Many thanks for your answer. Ok sure, your hint is one possibility but the problem is that our
engineers (which partly could, but usually don't use AutoCAD for static calculations and all the
corresponding tables) often create different Excel tables with advanced text or impressions we
also would like to insert in our drawings for additional information in an easier way.
If those tables will get no changes anymore it's ok to use them unlinked in our drawings. But
sometimes those tables are still temporary and will be finished or corrected later on, so it would
be nice this linking procedure works the same way like the unlinked procedure nicely does.
Maybe I have to pass on this problem directly to Autodesk. It's interesting it seams no-one
knows how this random space is generated. But reading around the web about Excel an OLE
showed me there are still problems to solve.
Have a nice day and thanks for replying!
Chris
Message 4 of 8
jggerth
If it's a straight excel table, then datalinking a table can update with any changes to the excel data.
If it's something fancier w/ charts and graphics etc, then another option to ensure the image in Acad is always current would be to print the excel to PDF and attach the PDF.  whenever the Excel spreadsheet is updated, simply reprint the PDF over the previous version.
The thing to remember about OLE and CAD is that it's like a dancing bear -- the amazing thing is not that the bear dances well, it's that the bear dances at all!.
Message 5 of 8
TerryDotson
If neither OLE nor Tables satisfy you on Excel importing, take a look at XL2CAD.
Message 6 of 8
Hi again, JGearth
"The thing to remember about OLE and CAD is that it's like a dancing bear -- the amazing thing is not that the bear dances well, it's that the bear dances at all!."
So we can be glad, AutoCAD can perfectly insert an Excel-table without any linking -- but the amazing thing is AutoCAD already knows something about importing an Excel-table! Smiley Wink
@TerryDotson
Many thanks for the hint, too!
Best regards both of you!
Chris
Message 7 of 8
With me, the empty rows and columns also shows up with unlinked Excel-tables
This is new in AutoCAD 2018
I have used the unlinked Excel-table as OLE object in AutoCAD ever since it became an option (R14? back in 1997?)
I despise the table-"functionality" in AutoCAD. For me it is useless.
Excel excels(!) in creating a table quick and easy - with ease and swiftness in getting the layout exactly as I want it.
Cut from Excel, paste into AutoCAD, scale, and voila - it is perfect!
I don't need a live link OLE. I don't need to keep track of an additional/extra excel file. If I need to edit the table (i.e. OLE object) I simply OLEOPEN the object, and inserts as new if I add/remove rows/columns
Now, Autodesk seems to have messed up this functionality as well...
Who can tell Autodesk not to fix things that ain't broken?!?
***sigh***
Anyone have a fix NOT involving Autocad table??
//PU
Message 8 of 8
todd36L7A
Observer
Observer
I fixed the empty space to the right of the table by making my table (which was on a MS Word sheet) extend across the entire page. The empty space that was showing was the distance to the side of the sheet.
