Anuncios
Excel data extraction from AutoCAD shows DeleteMe in spreadsheet
MikeKovacik4928
MikeKovacik4928
Hi  there Autodesk employees and Autocadders of the world
I have developed a way of automating my quantities lists in AutoCAD using the "eattext" function
I have tried it on 3 different machines, with the same files, my desktop at home (AutoCAD 2018 on Windows 7), my laptop at home (AutoCAD 2018 on Windows 7) and my desktop at work (AutoCAD 2018 on Windows 7). I haven't tried it at work on AutoCAD 2019 on Windows 7 yet as I do have 2019 at work but not at home.
It seems to work okay for smaller test examples, but when I try it on a real life drawing which is quite big with a lot of blocks it seems not to work and come up with the above error message in the excel spreadsheet.
I have read up on it through the Autodesk forum and came up with attached pdf .
See also attached jpeg to show what windows I have here on my laptop at home.
Which windows updates do I need to install?
The windows 7/2008 R2?
The monthly rollup or the security update or both?
I have spoken to my IT person at work and he says windows at work automatically updates and thus is completely up to date. Why is then happening at work as well? Do I need to intall these 2 windows updates at work as well?
Michael Kovacik
2d & 3d Autocad and Inventor designer/draughtsman
Draughting/Designing (Manufacturing) (31 yrs)
-Drawing Board (3 yrs)
--Cad (28 yrs)
---Cadkey (4 yrs)
---AutoCAD 2d & 3d (16 yrs)
---Inventor (4 yrs)
---Autocad and Inventor Simultaneously (4 years)
---(and recently Autocad/Inventor Customisation)
Authorised Autocad & Inventor Professional
Authorised Autodesk Trainer
Higher Diploma Mechanical Engineering
Autodesk Product Design Suite Ultimate 2018
Autocad 2018, Inventor Pro 2018
(personal licensed copy)
Johannesburg, South Africa
(Impossible only means you haven't
found the solution yet)
0 Me gusta
Responder
750 Vistas
4 Respuestas
Respuestas (4)
cadffm
First: Make sure it is a windows update problem.
Test it again with a DWG and XLS Filepath and name without any special characters.
For example: APOSTROPHs force the "delete.me" effect too.
Then check your win updates. Is kb4048957  or similar to your os version installed?
https://support.microsoft.com/en-us/help/4048957/windows-7-update-kb4048957
Sebastian
MikeKovacik4928
Will investigate here at home this evening and tomorrow at work and get back to you
Mike
0 Me gusta
MikeKovacik4928
Apologies for not finishing this topic
AQ 069_Excel data extraction from AutoCAD shows DeleteMe in spreadsheet_007.jpgm
This one was never solved. I have temporarily given up on it. My IT guy at work was not
successful in getting it working when I passed him all the info. At work windows updates
are done automatically as and when they come in.
At home, I usually don't bother with the windows updates.
It sometimes works, sometimes doesn't. It tends not to work on the bigger assemblies.
It also tends not to work more at work, where we run off a server, than at home where
I just work off my C drive.
I would still, one day like to get to the bottom of it.
Michael Kovacik
0 Me gusta
cadffm
We waiting for you since three weeks :cara_guiñando_un_ojo:
And we are waiting for feedback to our answers:
Thats the IT Part, but you say it is updated. OK.
 I am missing your test feedback&result.
Test it again on a local drive with a DWG and XLS filepath name without any special characters.
Sebastian
