When I open a new drawing my DIMSCALE is set to 0'-0 1/4". Why does this change every time I open a drawing.
The issue is that once the dimscale is set for a drawing, I would like it to not change at all and I am finding that I will close a drawing when my dimscale is set to 48, reopen that same drawing and then it will change to 0'-0 1/4".
Any ideas? I tried looking into my ACADDOC.lsp and nothing in that changes anything, at least that I am aware of. Below is exactly what is in the ACADDOC.lsp;
;;;;;;;;;;CREATED BY RANDY CARMINATI;;;;;;;;;;;;;;;;;;;;;;;;;;;
(defun C:VPL (/ ss n vp); = Lock All Viewports
(repeat (setq n (sslength (setq ss (ssget "_X" '((0 . "VIEWPORT"))))))
(if (> (cdr (assoc 69 (entget (setq vp (ssname ss (setq n (1- n))))))) 1); not the Paper Space Viewport of its Layout
(vla-put-DisplayLocked (vlax-ename->vla-object vp) -1); lock it
); if
); repeat
); defun
(C:VPL)
(defun c:navvcubedisplay "0")
(command "insunits" "0")
