Etransmit freezes when xref unloaded
nflores9LVE8
Message 1 of 8
nflores9LVE8
I have a drawing with about 20 exrefs that freezes during etransmit if any xref are unloaded.
If i reload all the xrefs, the etransmit dialog opens in about 1 second.
If i unload a single xrefs, then the etransmit freezes again.
Well it doesn't exactly freeze.
The Command line says 'Updating Fields...' and goes through a list of 'Loading MEP Base'
At the same time the progress bar goes into an endless flickering cycle of 'Synchronizing References', 'Reading triangles from file...', and 'Upgrading old drawing'. And eventually i have to End Task AutoCAD.
This is happening on this project only, across several people's computers, across many different files. They are all using the same xrefs. All the xref have been Audited, Purged, and even Scale lists cleaned up.
Same issue, all xrefs loaded, no problem. Unload any xref and etransmit doesn't work.
Any help is super appreciated. Thank you.
I'm using Civil 3D 2023 3.1 on Windows 11
Replies (7)
Message 2 of 8
pendean
Community Legend
Community Legend
Q: are you just trying to 'exclude' all XREFs from being bundled with your top file when you use ETRANSMIT command? Just trying to understand your "unload xrefs" first step.
TIA
Message 3 of 8
nflores9LVE8
Thanks for the quick reply.
Some xrefs will be bundled into the ertransmit but not all. We keep them unloaded in the file to reload for our reference as needed when designing.
This workflow is the same across a couple hundreds project, but this is the only project with this issue.
Message 4 of 8
pendean
Community Legend
Community Legend
@nflores9LVE8 wrote:
... This workflow is the same across a couple hundreds project, but this is the only project with this issue.
If I may ask, is this unchecked?
If it is... how is this one project different from all the others? Something minor or significant is, not sure we can help remotely here but many folks will share ideas as they stumble in here.
I see a few similar posts in a Google Search, many seem to suggest fixing the individual files as a cure like this one
https://forums.augi.com/showthread.php?157181-E-Transmit-Hanging
Message 5 of 8
nflores9LVE8
No that option is not checked.
You're correct, there is something different about this project, otherwise this issue wouldn't exist. This project is very large. It has about 140 xrefs, and 100 data shortcuts across several shortcut folders. A lot of files are referencing each other.
Thank you for that link. We have audited and purged the files, but we will do it again in case it helps.
A new piece of info:
Unloading consultant backgrounds does not cause this issue. Only unloading files that have been created and managed by our company causes this hang up. The only difference between ours and consultant files is the template they start from, and our files are Associated with Civil 3D projects. I'm not sure what other differences they have.
Message 6 of 8
paullimapa
Could be a Civil 3D issue. If you have access to plain AutoCAD that would be worth a try.
Also if possible to just detach all the xrefs you want unloaded and try eTransmit after that.
Paul Li
IT Specialist
@The Office
Message 7 of 8
pendean
Community Legend
Community Legend
...The only difference between ours and consultant files is the template they start from, and our files are Associated with Civil 3D projects. I'm not sure what other differences they have.
That could be something worth asking in the dedicated C3D forum while you wait here for more ideas: plain AutoCAD's DWG files are not live-linked to to project templates in any way. Here is the link
https://forums.autodesk.com/t5/civil-3d-forum/bd-p/66
Message 8 of 8
Valentin_CAD
@nflores9LVE8 ,
... All the xref have been Audited, Purged, and even Scale lists cleaned up.
You mean "All" of your "about 140 xref" have been Audited, Purged, and -Purged [RegApp]?
Install the latest updates:
Look into:
Select the "Mark as Solution" if my post solves your issue or answers your question.
Seleccione "Marcar como solución" si mi publicación resuelve o responde a su pregunta.
Emilio Valentin
