errors while build and run old vs c# project while referencing autocad 2019
I am trying to fix a bug in old 2003 vs project created a long time ago in my company. The project references an old autocan version (not sure which version. If it is important I will find it  in one of the following days when someone will be in he office).
At my computer at home I have Visual Studio Community 2017 and I installed an autocad 2019 to test if I can build the old vs project.
I get  about 100 errors of un-recognized type or namespace such as Interop, AcadApplication, AcadDocument, AcadEntity, etc...
I do see that some autocad includes succeed, for example:
using Autodesk.AutoCAD.Runtime;
using Autodesk.AutoCAD.DatabaseServices;
using Autodesk.AutoCAD.ApplicationServices;
using Autodesk.AutoCAD.EditorInput;
using Autodesk.AutoCAD.Geometry;
I tried to find a solution in google and in the forums here and in VS.
I understood that it is probably related to adding references to the project, so I entered the COM part of the Reference Manager and added all the autocad 2019 Type Library, all the autocad Map MPolygon Type Library and all autocad/ObjectDBX Common 23.0 Type Library.
It didn't help either.
Help will be very appriciated.
h_s_walker
LT cannot run VBA projects.
Howard Walker
Left Handed and Proud
If LT can't be used, is there a different version that I can try to istall and connect to?
h_s_walker
Full AutoCAD. You should be able to download a 30 day trial of 2019 to have a see if the program will work
Howard Walker
Thank you.
I have uninstalled th LT version and downloaded and installed the full version.
I found the extra reference: AutoCAD Focus Control for VBA Type Library and added it, but all the references are still not recognized.
pendean
Community Legend
Community Legend
The VBA Customization forum is over here, its time to move your questions/queries my friend https://forums.autodesk.com/t5/visual-basic-customization/bd-p/33
Alfred.NESWADBA
not sure why anyone here writes about VBA?
That sounds like
  • you need to set your project to Framework 4.7
  • you need to add a reference accoremdg which was not needed/not available before AutoCAD 2013
HTH, - alfred -
Alfred NESWADBA
(not an Autodesk consultant)
