AutoCAD Forum
Error with Data Extraction for block counts
2 REPLIES 2
Sarah.Rose.Sardar
719 Views, 2 Replies
Sarah.Rose.Sardar
Hi Guys,
    I've successfully set up a data extraction table to list active blocks in a drawing. However, there seems to be an error when I 'Update Data Extract'. If I copy and paste a block in the DWG and 'Update Data Extraction', the total doesn't update. But, if I delete a block then it does update. Can anyone tell me why the total will only reduce and not increase?
Thanks guys!
Hi Guys,
Thanks guys!
Labels (4)
2 REPLIES 2
imadHabash
You have this issue because in Data Extraction ( Page 2 of 8 ) you have uncheck the option Select objects in the current drawing and depend on the above options .. Now either you add or delete your block the count will modified when you update the data extract .
Imad Habash
Imad Habash
Sarah.Rose.Sardar
That's great! Many thanks for your help!
AutoCAD Inside the Factory
