Error while plotting to pdf
shafiqsaidee
shafiqsaidee
Hi everyone!
I get error while plotting to pdf. Even if I publish selected layouts still it give problem.
I tried the following to plot to pdf.
1. run audit command the file was ok with no errors.
2. Changed different plotter with .pc3
3. Export to PDF
4. publish layouts
But plotting to pdf still gives error.
The dwg file closes unexpectedly even to
FATAL ERROR: Unhandled Access Violation Writing 0xdd53a8a0 Exception at dd53a8a0h
Previously, I didn't get any error when plotting but recently I install new updates to Autocad 2018.
I tested the same dwg file into another computer which run autocad 2018 while having no errors during plotting to pdf.
[Please find attached the file test.dwg.]
imadHabash
with DWG to PDF.pc3 plotter , there is NO error . would you try to plot from the attached CAD file again ?
Imad Habash
shafiqsaidee
Hi
I got the same error from the attached CAD file.
imadHabash
since you install the latest CAD updates successfully . right click on your desktop CAD icon and run as administrator , any changes ? also if you try from another new CAD drawing does the same error appear ? also if you try to delete your plotter ( DWG to PDF.pc3 ) and copy another one from another same version ( same name an same version ) , any changes ?
Imad Habash
shafiqsaidee
I deleted  ( DWG to PDF.pc3 ) and created new one. And it did work well no error during plotting.
Thanks from sharing your experience appreciate it.
Best regards
imadHabash
Great ... you're welcome !
Imad Habash
