error when trying to install
hello i downloaded autocad 2016, when i try to run the installer a message pops up "Error 1327. Invalid Drive E:\ i click ok and another message pops up Fatal error during installation. #424: failed to run AdskExecuteSequence. i click ok again and another message pops up "Failed to initialize Autodesk Autocad 2016. after this i try to fill in the product infomation and when i click next it displays the same messages again. help!!!
john.vellek
Hello @Anonymous
This doesn't sound fun. The #1327 typically refers to a missing drive! Did you run the install as an Administrator on the workstation?  I would try the 2nd and third steps below to see if it eliminates the error messages upon installation. Make sure that you run the install from a stable and accessible drive.
Please hit the Accept as Solution button if my post fully solves your issue or answers your question.
John Vellek
john.vellek
@Anonymous
I am checking back to see if the processes I outlined assisted you in resolving your install issue.
John Vellek
I get the same error messages how can I fix my problem
john.vellek
HI @Anonymous,
Welcome to the Autodesk Community!
I suggest you review the steps in Post no. 2 of this thread.  Please let me know if you require clarification or more assistance.
John Vellek
I did what the removal says but I still have the same problem it wants to install on drive I what I don't have on my pc
john.vellek
Hi @Anonymous,
There are a couple options here.
The first would be to subst a drive letter for your local path. This can be done by following the instructions here.
The other option, the one I would use myself, is here:
  1. Back up your Registry.
  2. Select Start> Run> and then type Regedit.
  3. Navigate to the following folder:
    HKEY_CURRENT_USER\Software\Microsoft\Windows| CurrentVersion\ Explorer\User Shell
  4. In the right panel, search for entries that list the incorrect drive.
  5. Modify the incorrect drive to point to C:\.
Please select the Accept as Solution button if my post fully solves your issue or answers your question.
John Vellek
