Error Message_WRN: Assembly binding logging etc.
Hi, I have been moved to a new domain. Since moving I get the error message below. I have lost a lot of functionality in AutoCAD. It was working well in the old domain. I googled the error message but the suggested fix didn't work.
Has anyone come across this message and been able to fix it?
Error Message:
WRN: Assembly binding logging is turned OFF.
To enable assembly bind failure logging, set the registry value [HKLM\Software\Microsoft\Fusion!EnableLog] (DWORD) to 1.
Note: There is some performance penalty associated with assembly bind failure logging.
To turn this feature off, remove the registry value [HKLM\Software\Microsoft\Fusion!EnableLog].
System.IO.FileNotFoundException: Could not load file or assembly 'AeccContextTabRules' or one of its dependencies. The system cannot find the file specified.
File name: 'AeccContextTabRules'
   at System.Reflection.RuntimeAssembly._nLoad(AssemblyName fileName, String codeBase, Evidence assemblySecurity, RuntimeAssembly locationHint, StackCrawlMark& stackMark, IntPtr pPrivHostBinder, Boolean throwOnFileNotFound, Boolean forIntrospection, Boolean suppressSecurityChecks)
   at System.Reflection.RuntimeAssembly.InternalLoadAssemblyName(AssemblyName assemblyRef, Evidence assemblySecurity, RuntimeAssembly reqAssembly, StackCrawlMark& stackMark, IntPtr pPrivHostBinder, Boolean throwOnFileNotFound, Boolean forIntrospection, Boolean suppressSecurityChecks)
   at System.Reflection.RuntimeAssembly.InternalLoad(String assemblyString, Evidence assemblySecurity, StackCrawlMark& stackMark, IntPtr pPrivHostBinder, Boolean forIntrospection)
   at System.Reflection.RuntimeAssembly.InternalLoad(String assemblyString, Evidence assemblySecurity, StackCrawlMark& stackMark, Boolean forIntrospection)
   at System.Reflection.Assembly.Load(String assemblyString)
   at Autodesk.AutoCAD.Ribbon.TabEvaluatorFactory.Compile(List`1 selectors, String assemblyPath)
   at Autodesk.AutoCAD.Ribbon.TabEvaluatorFactory.Load()
   at Autodesk.AutoCAD.Internal.Windows.RibbonContent.get_ContextualTabEvaluator()
natasha.l
Hello @Anonymous,
Thank you for posting to the community. Smiley Happy
You are on the right track with assuming its your Windows domain profile, it seems the profile is restricted having insufficient Windows permissions to run the software properly.
The software needs Administrator rights during installation & at first launch after installation. Also, the application should be set up to run as Administrator. Please have the IT Administrator help you uninstall & reinstall the product.
Please review the following links for further details:
Microsoft "Run as administrator" and Autodesk software issue ...
Unable to run AutoCAD as a restricted user | AutoCAD | Autodesk ...
How to set a program to run as administrator | Search | Autodesk ...
Local administrator rights and running Autodesk software | AutoCAD ...
Please "Accept Solution" if a reply or replies have helped resolve the issue or answered your question, to help others in the community.
