Error message while BCOUNT
makdezines
makdezines
Dear Experts,,
Solve the BCount issue while am trying to resolve getting attached error message
Command: BCOUNT
Press Enter to select all or...
Select objects: 1 found
Select objects: Specify opposite corner: 10 found (1 duplicate), 10 total
Select objects:
No valid objects selected.
pendean
Community Legend
Community Legend
Use LIST command to identify the items you are trying to select, let us know what object types these are please. Then look them up in BCOUNT help to see if they are supported.
OR if you are new you AutoCAD post your DWG file here and point to the 10 objects you are trying to use BCOUNT with for someone else to try.
makdezines
Kindly help with Tcount command its not working
displays as attached
pendean
Community Legend
Community Legend
Change commands for a reason? Or where you using BCOUNT incorrectly?
The error posted explains the problem with TCOUNT: use FLATTEN command on those to see if the problem goes away. Also ensure your UCS and PLAN commands are set to WORLD.
