Error Message when opening a drawing
sockhui
sockhui
when opening an autocad 2014 drawing, the following error message used to appear:
The procedure entry point
?testRenderHint@QPainter@@QEBA_NW4RenderHint@1@@Z could not be loaced in the dynamic link library QtGui4.dll
Just wonder what is this. when clicked 'ok' I am able to proceed.
Alfred.NESWADBA
either there are DLL's defect on your system or you have applications/tools/plugins installed on top of your system which do not fit to your AutoCAD version or service pack
If you upload your drawing we can look if we also have troubles with that file or not.
- alfred -
Alfred NESWADBA
(not an Autodesk consultant)
imadHabash
I suggest to reset your AutoCAD to default then see if your problem still existing or what.follow Here and learn how to reset.
Imad Habash
john.vellek
HI @sockhui,
I see that you are visiting as a new member. Welcome to the Autodesk Community!
This appears to be related to QTpainter. Do you have any add-ins or hyperlinks in your AutoCAD?
Can you attach a sample file to a post?
John Vellek
john.vellek
Hi @sockhui,
I haven't seen an update from you. Have you resolved your issue when opening drawings?
You might try logging on as a brand new user on your machine. Let me know if you see the same error message.
John Vellek
sockhui
There is no particular drawing having this problem when opening. The error message will pop up once in a while when opening any drawing. That is when opening the same drawing, this error message may not pop up. I will try the 'Reset Setting to Default' and wait to see if this error will pop up again.
Thanks everybody for the possible solution
