Error message 005.111
I have had to replace the hard drive of my computer and am trying to re-activate Autocad. Where do i get a case number from?
ennujozlagam
hi, you may want to check it here.
Click HERE
Error message 005 111 I when Try to activate autocad
DarrenP
what version of Autocad?
depending on the version Autodesk may not give you an activation code
DarrenP
AutoCAD 2010.
Michiel.Valcke
For old (no-longer supported) versions of AutoCad (with a permanent license), for which you need to do an activation, you will need to contact AutoDesk support. Only they can manually activate your software.
pendean
Community Legend
Community Legend
Autodesk ended automatic reauthorizing of 2010 and older software as of August 31 2019, read all about it here https://knowledge.autodesk.com/support/autocad/learn-explore/caas/simplecontent/content/previous-ver...
Sorry, you missed the deadline. There is nothing you can do about it today. Nothing.
