AutoCAD Forum
Error in Presspull command
11 REPLIES 11
Message 1 of 12
2069 Views, 11 Replies
When I click on Presspull, the curser keeps loading.
All other tools are working properly, even Presspull is working fine in other files but not only in the current working file.
I tried restarting the laptop still, the problem is the same.
Please help me, I am a beginner, what should I do?
Labels (3)
11 REPLIES 11
Message 2 of 12
Alfred.NESWADBA
If this behavior is related to one special file then we need this file to see what's in that.
Also please let us know which version of AutoCAD you are using.
- alfred -
Alfred NESWADBA
www.ish-solutions.at ... blog.ish-solutions.at ... LinkedIn ... CDay 2024
(not an Autodesk consultant)
Message 3 of 12
imadHabash
Would you please attache here your CAD dwg file for testing ?
Imad Habash
Message 4 of 12
in reply to: Alfred.NESWADBA
Firstly, Thank You for your response.
My Product Version is: R.47.0.0 AutoCAD 2021
I am attaching the DWG file here, Please let me know if it is not accessible due to any error.
Message 5 of 12
in reply to: imadHabash
Thank You for your Response.
Product Version: R.47.0.0 AutoCAD 2021
And here is the file,
Message 6 of 12
imadHabash
Presspull command when active it will do some thing like analyzing procedure. this error caused by the lines that locate below your 3d solid object . try to move the 3d solid object then try to Presspull to find it will successfully active . i suggest to erase all those lines to get rid from this error
Imad Habash
Message 7 of 12
WOW, It actually worked.
Thank You So Much!!!
Message 8 of 12
My presspull command is not working in an important drawing file. What to do? Please somebody help me.
Message 9 of 12
My presspull command is not working. Please somebody help me
Message 10 of 12
imadHabash
Make a new post ( Message )  and try to describe well your issue please ?
Imad Habash
Message 11 of 12
When I use presspull command, The prespull command is not working in only one file. /storage/CC08-15FD/Alarms/House plan 2.dwg
Message 12 of 12
garrygoldberg1
The best way to choose a software development company is to research them thoroughly. It is important to choose a company with experience and references from satisfied customers. Check their websites and blog posts to see if they pay attention to detail. If they have a presence on Twitter and LinkedIn, you can find out if they write on related topics. If they have a blog, make sure their philosophies align with yours. You should also look for affordable rates. Though a cheaper option might seem attractive at first, you may end up with a product that does not meet your expectations. In addition, a company that is too cheap to be professional may not have sufficient experience in outsourcing projects. In addition, a reliable process and transparent communication is essential. Instead of searching for the cheapest option, you should focus on the rates and the portfolio of previous similar projects. A successful software development company must have satisfied clients in a variety of industries. Once you've identified a good software development company, it's time to choose the right one for your project. You'll be surprised how many options there are in the market. The key to finding the right one is to define your critical requirements and create a checklist of requirements that you need for your software project. This checklist will serve as a filter for the companies that fit the bill. Then, you can begin the selection process.
AutoCAD Inside the Factory
