Anuncios
Error converting to PDF
No aplicable
I wanted to pass a layout to PDF using the plot option. I selected DWG to PDF (in addition to already having configured the size, the scales, etc.) and then I pressed the option Ok.
The PDF started to be generated and it was when an error occurred that closed the program.
I sent a report of the problem and the solution was to install AutoCad 2018.1 but after searching for a long time, I can't find this option in AutoDesk Deskop App.
I already tried to reinstall and repair the program but nothing has worked.
0 Me gusta
Responder
Soluciones aceptadas (1)
603 Vistas
3 Respuestas
Respuestas (3)
vinodkl
You will be able to find your updates here:https://manage.autodesk.com/cep/#products-services/updates
ವಿನೋದ್ ಕೆ ಎಲ್( System Design Engineer)
Likes is much appreciated if the information I have shared is helpful to you and/or others.
Please mark "Accept as Solution" if my reply resolves the issue or answers your question, to help others in the community.
0 Me gusta
No aplicable
Thank you but it was one of the first places I checked, the Autocad 2018.1 update option does not appear to me
0 Me gusta
vinodkl
Solución aceptada
Have you tried the solution given in this link below?
https://knowledge.autodesk.com/search-result/caas/sfdcarticles/sfdcarticles/Missing-product-updates-...
0 Me gusta
