error: COMPILE ERROR IN HIDDEN MODULE: frmMain
Good morning in autocad with windows 8.1 I try to open a template and when I click on Enable Macros I get the following error: COMPILING ERROR IN HIDDEN MODULE: frmMain
At the same time I am technician and install all versions of windows 8 and do the same, install the different versions of autocad and do the same, install versions of Visual and do the same. On a single laptop with windows 8, click on the image to view it.
Some advice on where to start again..
Libbya
You're posting on the wrong forum.  This is the 'dynamic blocks' forum and your inquiry has nothing at all to do with dynamic blocks.
