AutoCAD Forum
error AutoCAD 2016
1 REPLY 1
234 Views, 1 Reply
error AutoCAD 2016
Good Morning,
I need your help , I have problems with the software AutoCAD, DWG to open any document , open the following windows and not let me do anything .
install ATOCAD 2 times, but still with the same problem, I can help me.
1 REPLY 1
matthew.d
Hi @Anonymous,
Welcome to the community!
Sorry to hear about the issue. This may happen for a variety of reasons:
You could be using function from the previous version of AutoCAD. Could you make sure these functions you are calling in your projects are available with the version of AutoCAD you are using? Where are you getting the drawings from (which version)?
Could you also check the virtual memory settings of your computer? What is this set at?
Are you using the latest service pack for 2016?
Matt DiMichele
Autodesk Product Blogs | @ADSKCommunity Twitter
Likes are greatly appreciated. Everyone enjoys a thumbs up!
Please Accept As Solution if this resolves your issue, to help others benefit and locate it.
Forma Design Contest
