Show only
Search instead for
Good Morning, I need your help , I have problems with the software AutoCAD, DWG to open any document , open the following windows and not let me do anything .
install ATOCAD 2 times, but still with the same problem, I can help me.
Sorry to hear about the issue. This may happen for a variety of reasons:
You could be using function from the previous version of AutoCAD. Could you make sure these functions you are calling in your projects are available with the version of AutoCAD you are using? Where are you getting the drawings from (which version)?
Could you also check the virtual memory settings of your computer? What is this set at?
