Anuncios
Error After Install AUTOCAD 2014
No aplicable
Hi There,
I have problem with my AUTOCAD 2014, when im done with my installation, it appear an error like this. When i click OK the Autocad suddenly close.
Can anyone help me with my problem?
Gunawan
0 Me gusta
Responder
Soluciones aceptadas (1)
749 Vistas
7 Respuestas
Respuestas (7)
lynn_zhang
Hi @Anonymous
Have you tried the solution in this article: FATAL ERROR: Unhandled Access Violation Reading 0x0000 Exception at 4048b9h?
Lynn Zhang
0 Me gusta
Alfred.NESWADBA
in your screenshot (on the top border) there is a small item showing "Install now" ... from which application did that come from?
And always a good test to verify dependancies from Internet (AutoCAD is calling home) or from network (AutoCAD verifies network folders, printer/plotter, ...) is to disable/unplug the workstation from network and then try to start AutoCAD.
- alfred -
Alfred NESWADBA
www.ish-solutions.at ... blog.ish-solutions.at ... LinkedIn ... CDay 2025
(not an Autodesk consultant)
0 Me gusta
No aplicable
Hi @lynn_zhang,
Sory for late reply, i have already read your article you provide. In there describe that we must search acsignopt in the Search programs and files field. But when i search it on my PC, it doenst appear
Can you help me?
Gunawan
0 Me gusta
No aplicable
Hi @Alfred.NESWADBA
About "Install Now" notification, it comes from AUTOCAD it self. Its notification to upgrade my current product, this is the screenshoot :
And about your suggestion to disable/unplug the workstation from network and then try to start AutoCAD, i have done that. But its unsuccessfull
Gunawan
0 Me gusta
Alfred.NESWADBA
Thank you for your info, never thougth about that it's AutoCAD itself :cara_guiñando_un_ojo:
As you got the information about updating the product ... do it, may be that solved your issue!
- alfred -
Alfred NESWADBA
0 Me gusta
No aplicable
Solución aceptada
@Alfred.NESWADBA I cant do that Alfred, the pop up FATAL ERROR blok me Emoticono triste . But anyway i can solve this case by my self. The problem lies in user account profile. When i try to open it with other user it work well. So, i just need delete my current account, and relog with brand new "current user". Im using Active Directory bytheway. Thanks all for your advise Guiño
Gunawan
0 Me gusta
Alfred.NESWADBA
>> I cant do that
You would have been able to start the service pack installation also by manually find and download the service pack and install it from the downloaded exe.
That can also be just a defect AutoCAD profile, look to >>>that article<<<, maybe you don't need to recreate all your user settings for all your programs then.
Anyway: good you have found a solution to continue working well :cara_guiñando_un_ojo:
- alfred -
Alfred NESWADBA
0 Me gusta
