Error 1325 - AutoCAD 2016
Issue:
Network users are not able to properly launch AutoCAD for the first time. MSI starts configuring and 3 prompts of invalid short name appears, followed by AutoCAD 2016 crashing. This is the exact same behaviour as 2014. We have a workaround, though it is not one we can use permanently.
Steps to Replicate:
- Install as Administrator
- Run for first time as admin
- Export HKCU Autodesk key/subkeys and import with user
- Copy over the local/roaming Autodesk folders to user profile/appdata
- Launch as local (non-admin) user
Troubleshooting Steps:
I have followed the steps in article http://www.cadforum.cz/cadforum_en/msi-error-1325-username-is-not-a-valid-short-file-name-tip6686 which worked for the initial installation and allows the software to be run if the user is a local administrator on that machine. This is not good.
I also followed this article http://usa.autodesk.com/getdoc/id=TS1055299 about permissions for "expected AutoCAD startup behavior" and those didn't seem to make a difference.
I was also told that the following needs to be accessible by all user accounts:
- C:\Users\All Users\Autodesk
- C:\Users\<the current user>\AppData\Local\Autodesk
- C:\Users\<the current user>\AppData\Roaming\Autodesk
- C:\Program Files\Common Files\Autodesk Shared
- C:\Program Files\Autodesk
- C:\ProgramData\Autodesk
After doing all of this I am still given the same short name error when a user tries to run AutoCAD 2016 for the first time.
Next Step:
Is anyone familiar with log files that are generated when AutoCAD loads and could possibly post their locations? I'd like to see exactly what is triggering the MSI from activating on a regular user account and not an administrator account.
Thanks in advance to anyone that can help, and in turn hopefully help countless others facing a similar (if not, the same) issue.
