Anuncios
ERASING MULTIPLE BLOCKS
No aplicable
I've been working on a job where I need to show multiple copies of a block.
In this case I'm showing multiple sets of parking spaces for a parking lot.
Well as I decide to make changes and remove some of the blocks so that I can rearrange the lot I'm having trouble picking multiple blocks to delete.
What's happening is that when I'm zoomed in close enough to be able to safely do a crossing to select items, if I also pan while in the middle of the process it will only delete the blocks that are visible on my screen.
Dropping the ones that I had selected before pan further along in the lot.
I've been using Architecture 2016 if it makes a difference.
Is there a setting that can be adjusted to keep this from happening?
It's just a nuisance!
Thanks for any help.
Radar
0 Me gusta
Responder
253 Vistas
2 Respuestas
Respuestas (2)
pendean
Community Legend
Community Legend
Delete what you can see before you move on is probably best practice anyway: the DEL key on your keyboard speeds the erase function immensely.
0 Me gusta
No aplicable
Well that is the process I've had to follow but it sure seems like this wasn't a problem with older versions of the program.
0 Me gusta
