EPS/PSOUT changes linetype scale
No aplicable
Why do the linetype scales change when I create an eps file using psout?  I want the eps file to look just like my CAD file.
0 Me gusta
Responder
645 Vistas
2 Respuestas
Respuestas (2)
wispoxy
Same as the lineweight issue.
When you use these commands to export objects in a drawing to PostScript file format, certain features, such as lineweight, are not included in the exported EPS file. As an alternate method, you could set up a plotter configuration using the PostScript device HDI driver, and then plot the drawing to a file to create an EPS file with lineweights.
If you want to continue to use PSOUT, you can create a prolog setting in the PostScript support file (acad.psf for AutoCAD® software or aclt.psf for AutoCAD LT® software) to specify the line widths for the PostScript output (that is, for printing or plotting, and saving to a PostScript file). By modifying the PostScript support file and using the PSPROLOG command prior to using PSOUT, you can assign line width to objects based on their color. For example, you can specify that red objects plot with one line width, and blue objects with another.
Note: Line widths assigned using this method are not displayed in the drawing window; they are only evident when the EPS file is viewed in another application, or plotted.
For detailed information about modifying the PostScript support file (acad.psf or aclt.psf), refer to Help in the product.
Article ID: kA230000000tcZ7
Issue can also arise if the file was created by an application older than 2004.
0 Me gusta
Alfred.NESWADBA
Linetypes in AutoCAD are completely different to linetypes in EPS. In AutoCAD you can create quite complex linetypes based on line-segments, characters and symbols, nothing of that is possible with EPS so the export has to convert entities.
I don't know your workflow, so which software then should import the EPS, but I would suggest to export all lines with linetype continuous and assign the linetypes in the software you are continue to work with the geometry.
For other/better suggestions let us know what exactly changed (show your AutoCAD screenshot and the screenshot where you then imported the EPS so we can see what changed and let is know a bit of your workflow.
- alfred -
Alfred NESWADBA
(not an Autodesk consultant)
0 Me gusta
