entity cannot be gripped
I was sent a model generated by software I presume. Nothing can be gripped. Where do I round up the usual suspect?
Alfred.NESWADBA
If an object can be selected but not gripped in most cases the object
  • is placed on a locked layer ==> unlock the layer
  • is a proxy object ==> check which proxy and see if there is an object enabler available.
If nothing helps let us at least know which type of object that is.
- alfred -
Alfred NESWADBA
(not an Autodesk consultant)
pendean
Community Legend
Community Legend
Show us the DWG file with the object in it.
braudpat
Hello from France
+1 with Alfred & Pendean !
Q1) Just a "stupid" question : we are speaking about a DWG (or DXF) file, I presume ?
Q2) Coming from AutoCAD 20xx or coming from an OTHER CAD program ?
Regards, Patrice
Patrice ( Supporting Troops ) - Autodesk Expert Elite
If you are happy with my answer please mark "Accept as Solution" and if very happy please give me a Kudos (Felicitations) - Thanks
Patrice BRAUD
Called the sender. He said this is a bundled XREF for review so it cannot be gripped. The drawing is too big to be uploaded. Yes. It is a dwg file.
